Vray Denoiser - It`s there a way to denoise VRayLightSelect Render Element?
Thank you, Zdravko, for replying. It is much appreciated but unfortunatelly I could not get a good result yet.
I tried the following methods.
1 - used Vray Denoiser Tool in order to denoise a .vrimg output wich contains Denoiser Elements but it will only use the denoiser for the RGB not for other Render Elements like VrayLightSelect as I need;
2 - used Vray Denoiser Tool in order to denoise single render element .exr output wich don`t have the Denoiser Elements but the result is not so good;
Can you please give me more input regarding the workflow that I should use?
We are working on this feature and it will be available in a next version of V-Ray. In the meantime we might release an updated version of the vdenoise tool that can denoise additional render elements.
That would be great!
Is it going to be vray 4.0 or 3.7?
Simply, I love to put pixels together! Sounds easy right : )) Sketchbook-1 /Sketchbook-2 / Behance / Facebook
it would be fantastically useful to have the render elements denoised and remain separate.... would it be possible to have the -elements switch with a 3rd option to not combine the elements after the denoise process ?
Any news on an updated denoiser tool we REALLY need this for comping in after effects. Thanks
